Old 03-26-2025, 07:45 PM
Maximus1 Maximus1 is offline
Default Radiator Question
I installed the lower bracket per the manual. I then rested the radiator that I got from A&C, with it the leaned forward, resting against the bottom tabs. The outlet for the radiator looks to be an issue. The hose will run right into the steering column boot. Simply, I don’t have the clearance needed. Has anyone has this issue, and what was your fix? I’m thinking about seeing if I can get the radiator outlet changed to a 90 degree.
