Old 07-04-2025, 06:52 AM
6t8stang's Avatar
6t8stang 6t8stang is offline
Cobra Make, Engine: BDR#436 - 351W - 450HP / 429TQ
Originally Posted by Toddh03 View Post
I had hoped that someone over the past couple days would have replied and helped me with the correct 1156 & 1157 LED bulbs for my new Backdraft Cobra but perhaps no one has read he above posted yet.
Could someone please share with me the correct LED bulbs to order so the LED's will actually blink correctly and the 1157 LED's will also fit my running light / brake lights housing assembly.
I have read where alot of the 1156 & 1157 LED's won't properly fit the Backdraft running lights housing assembly, so there has to be a certain bulb/brand that everyone is using and that's what I need help with....knowing which ones to order, please!
Thanks in advance,
Todd
You’ll find many things with these cars need to be modified in some way to work as you desire. This is an old thread and it’s been way too long since I retrofitted mine with LEDs. Find some that are close to the size to fit in the housing. Solder the wiring if needed. Add a resistor if needed.
Eric
