Old 12-09-2025, 09:53 AM
jasond29 jasond29 is offline
Just spoke with Peter and Bob and got the info I need. The rear rotors are from a c4 corvette 88-96 part number acdelco 177-685. They are redrilled to the correct 6 pin bolt pattern. Wilwood makes a 2 piece rotor for that application and they also sell blank hats that are the same dimensions. I am going to 3d print a jig and order the blank hats and correct rotor rings. This should make maintenance of the rotors in the future even easier because now I will be able to unbolt the rotor ring from the hat to remove instead of removing the hub. I will let you know how it turns out.
