Old 03-27-2026, 02:49 PM
jts359 jts359 is offline
Cobra Make, Engine: 347 Ford
Default Runs 15 minutes
Have you taken the air cleaner off and moved the throttle to see if gas is spraying out of the accelerator pump jet ? On my Supercharged Studebaker there is a tee in the fuel line and fitting with a .047 hole in it which sends fuel back to the tank thru another line , This helps to eliminate vapor lock , Ed
