03-27-2026, 08:39 PM
ct
Cobra Make, Engine: ERA, 428, 4 speed Toploader, Jag rear, Red with White stripes
Originally Posted by jts359
Have you taken the air cleaner off and moved the throttle to see if gas is spraying out of the accelerator pump jet ? On my Supercharged Studebaker there is a tee in the fuel line and fitting with a .047 hole in it which sends fuel back to the tank thru another line , This helps to eliminate vapor lock , Ed
Yes I have. Did you read all the pages in this thread?
Wouldn't that return hole cause a decrease in fuel pressure?
ERA#698 428, 4 speed Toploader, 3:31 Jag rear
