Old 04-05-2026, 04:36 AM
mrmustang's Avatar
mrmustang mrmustang is offline
Gold Star Contributor
Originally Posted by nuesing View Post
I meen the drive shaft from the diff to the wheels.
And yes, the CSX Coupe has an Camaro Diff. I realy now this, i have change the ratio.
Do you have the Superformance Owners Manual?
https://secondstrike.com/Technical/C...nersManual.pdf
Your actual differential is not a Camaro item per se as the center section was used in multiple GM products over the years, but it is a "Dana 44" (Dana-BTR) and that is what you need to state when speaking about it. Although, SPF also for a brief time used a "ZF" differential so you'll need to check the following url to see which one you actually have:
https://superformance.org/scof_tech_...ferential.html
A loss in translation was apparent here, you need a "rear axle", or "half shaft", the question now is, do you need a left or right axle assembly?
In addition, SCOF has a list of other tech features, but you must join to access them.
https://superformance.org/scof_tech_feature/
Bill S.
