No issues!
No, high compression is not a requirement. Like any setup, higher compression can be better........ but only if you have the right fuel!
They ran the old Ford cams in the races back in the day, and they worked to win the races, so why not? Many are running less cam than that with Webers successfully.
What is your engine setup?
Paul
Unique Motorcars 289 USRRC
1964 289 5-bolt block
Toploader and 3.31 rear
