Originally Posted by PDUB
Often it is activated by a pressure switch in the brake system, so that when you activate the pedal, pedal pressure turns on your lights. Look for something in line in the brake system near your master cylinder.
If on the brake line then it's an easy fix.
Mashing the peddle to get activation is a sign it's failing.
Ask me how I know.
I replaced mine with Allstar ALL76251 (bullet connector)
You can also use Allstar ALL76252 (two wire screws)
Rated at 60-120 PSI and 4.5 amps.
