Thread: Carbs
Old 07-02-2002, 10:15 AM
Whaler Whaler is offline
Clois just for my own info, I was wondering what stop busing you are using now and also what springs were you using before this change.
"Made a few changes ie: accelerator pump adj rod, changed springs in my distr (MSD 6A went w/ blue and small silver), all my advance should come in by 3100 RPM, also retarded my timing about 2 degrees. "
What is your initial or static set at with the 2 degrees taken off?
What RPM is your idle now?
Tim
