Thread: Carbs
Old 07-03-2002, 12:12 PM
Jim Downard Jim Downard is offline
Cobra Make, Engine: Classic Roadsters, 393 stroker, Tremec 3550, about 425 hp, MDA GT40 289
Clois,
I had the same problem with two different carbs. Buy a jet kit for the carb, ( I think the kit will be for model 1411 carbs) and use the instruction manual that came with your carb. The chart in the back with tell you what jets come std. in the carb. I ended up going two steps rich in cruise mode and one step in power mode. That pretty much took my flat spot away. You'll like the Edelbrock for the ease of changing the jetting.
Good luck,
Jim Downard
