Old 07-05-2002, 11:07 AM
gary_bowers gary_bowers is offline
Roadwarrior,
I run an SPF with the 385hp/351 crate motor in front of a 3550 with the .82 fifth. The car does have a rather low 1st gear as previously mentioned. 40 ish mph @ 6000 is correct. However with no trouble the car will launch in 2nd gear with only maybe 20 to 30 feet of wheelspin then hang on as it will pull to around 70 mph. At 60 mph in 4rth gear is around 3000, in 5th is around 1800. Engine has enough torque to pull down to 12-1300 in high gear and just drive away with no hesitation. This works for me but, as they say, your results may differ. Hope this helps. ... Gary
