Old 07-07-2002, 06:09 PM
Hi Scott The trouble a have with my trans was 2 problems, First when my engine passes 180 degrees on the engine the trans will not shift. I have driven my car at 60 to 80 mph in St. Lious Run&Gun and the shifting works perfect as long as the temp stays down. I have a 180 thermostat in the engine. It doesn't matter what gear it is in when this problem starts I have broken every spring clip on the shifter rods at the trans during this problem The shifter works fine and is adjusted as pre richmond gear. I have talked to tech and they said it is not the trans. Second problem is when the trans is cool it will not shift under wide open throttle with or without the clutch. If you unload the drivetrain for a split second it shifts fine with or without the clutch The clutch is a centerforce gold. 11 inch Everything is brand new when a brought it. I am trying a G-Force to fix the problem. I centered the bellhousing and replaced the pilot bushing twice, once with a bearing and then with a bronze bushing still the same problem. I will find this problem out 1 day when I have the time. Rich Lake
