Old 07-10-2002, 10:40 AM
Mike Braddock Mike Braddock is offline
Olaf,
I think you need to properly bench bleed the MC, as Roscoe said. Did you have this same problem with the 3/4" MC before you swapped in the 7/8"? How do the front brakes work? Have you removed the rear calipers and checked around the seals to see if they are leaking and you just can't see it? Note that you do not have to remove the MC(s) to bench bleed them, you only need to run a piece of tubing from the output port to the MC's reservoir and stroke the piston several times to remove all the air. Can you do this easily? If so, try and it and let us know what happens. Good luck.
Mike
Mike
