Old 07-12-2002, 04:44 PM
Jeff Frigo's Avatar
Jeff Frigo Jeff Frigo is offline
Cobra Make, Engine: ERA 454 S.O.
Won't be in St. Louis, but am going to the strip in the next couple of weeks. I will let you know. The trick to making hp is in the heads. Find yourself a good porting guy in your area. Should be able to get around 330 cfm on the intake side at .650 lift.
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
