Old 07-12-2002, 06:19 PM
jams's Avatar
jams jams is offline
Cobra Make, Engine: B & B
Default Tighten Raise Front Suspension
Hi, I need some help with this one....
I went with the tire and rim backspacing B & B suggested but the tires stick out beyond the wheel well. I can live with that but I can't live with the tires rubbing the fender. (I just got done fixing the problem with the tire rubbing the inner fender.) I have the stock Mustang II suspension. What can I do to stiffen or raise the front suspension to avoid the tire moving up and rubbing the fender.
Can I use adjustable coil-overs with stock mustang II suspension. If so, where can I get them???
Any other suggestions???
I will ask B & B on Monday but I need a little food for thought until then.
Thanks Jim
