  #33 (permalink)
Old 07-13-2002, 04:11 AM
Hotfingrs's Avatar
Hotfingrs Hotfingrs is offline
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
Bob, You can use a pcv valve to get negative pressure in the crankcase. That's what I use, and it does pull some vacuum. In one valve cover I have my pcv valve and in the other valve cover I have a vacuum break. If you have a oil dip stick hole, you'll have to fill it with atv. My vacuum break is set at 5 inches, so I'm always running negative pressure in the crankcase. After running the engine, you can pull the pcv valve and the sound is just like opening a can of coffee, pssssss, so I know it's working. Also with running a negative pressure you can use rings with less tension because the negative pressure seals the rings, and less tension is more horses......just my 2 cents for today
Jack
XSSIVE .....
