Thread: Front tires Rub
Old 07-13-2002, 02:31 PM
Dwight's Avatar
Dwight Dwight is offline
Default FRONT WHEEL RUB
JAMS
MY FRONT WHEELS RUB THE UPPER CONTROL ARMS WHEN TURNED ALL THE WAY. I WAS TALKING TO A GUY AT THE SPRING FLING AND HE SAID THERE IS A FACTORY CLIP UNDER THE TIE-ROD BOOT THAT YOU CAN REMOVE (BRAKE OUT). YOU MAKE WIDER REPLACEMENT FROM 3/4"OR 1" PVC AND CUT IT SO YOU CAN SLIP IT OVER THE ROD. TY-WAP IT OR PUT A HOSE CLAMP TO KEEP IT IN PLACE. REPLACE THE BOOT. I HAVE NOT LOOK AT MINE. BUT THAT THE WAY I REMEMBER IT.
ANYONE CAN JUMP IN AND HELP US ON TIRE RUB!!!!!!!!!!!!!!
