Old 07-15-2002, 06:53 PM
Double Venom's Avatar
Double Venom Double Venom is offline
JD.. if you follow Jacks solution or even just half of it, you will not have a heat problem in either footwell! Even our V-10's, that run 1190 degrees right at the corner of the footwell doesn't really effect the interior.
My 2-cents is... put in a Vintage heater/defroster. you will find it more than usefull!
DV...one more thing, put the battery in the trunk, right rear corner works great!
