Old 07-22-2002, 10:46 AM
FFR2231K FFR2231K is offline
Joel,
I had guy my age do it at the Goodyear place on Dundee in Wheeling. This is the same place I ordered the tires from and the manager mounted them. If you got the adjustable upper A-arms it is easy to weld on a couple of stamp to hold things in place. If you have the non adjustable A-arms, you will need to lock them down. Someone on the forum has an alum block that I have heard works well. I could not aford that so I used some 1/4" flat stock, drilled and taped 5/16 NF and welded them in place. I did that with the body on and it was a pain. If you can, get it done before.
Are you still looking for help with the wiring?
Mark
