Old 07-23-2002, 08:19 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
How are you all measuring spring rate? You need to compress the spring to about 20% it's travel, measure force. Compress to 80% travel, measure force. Difference in force over difference in travel. Removing a coil will increase the spring rate on a given spring.
