Old 07-25-2002, 06:49 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Similar issues. Used CR wiring harness, Ididit column with no ignition, and '70 Ford F150 dash mounted ignition switch.
Re-routing the Chevette column ignition wiring was a little trickier than expected with CR harness. Unfamiliar with Painless wiring nomenclature, so would call them to find out what connects to what.
Don't hook any ground wires up to the ignition switch.
You have a power in (Battery), accessories power out (Acc), ignition power (or Run) out (Ign), and start power out (St).
Here's how it works if you need to diagram it out, or check it with an ohmmeter. Key to left powers accessories (radio, gauges, fan relay control, - anything you want to go on/off with key). Key to right powers ignition (anything you want to go on/off with ignition. MSD box, electric choke) AND accessories through the Acc terminal. Key to start powers starter solenoid, AND ignition, BUT NOT ACCESORIES. It's designed that way to save power for starting, and save your electronics from damage due to voltage spikes.
The Start Out is supposed to go through a safety switch on the trans or shifter to prevent starting in gear.
Headlights & chassis lights are not powered through the ignition switch.
Have you looked at any of the B&M shifters. Hammerhead looks like nice unit for auto trans.
