Old 07-26-2002, 09:32 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
I use the Lokar with the 6" shifter. There are 2 types available. Either one will work. One mounts to the front of the trans, the other to the rear. You will need to mount the shifter over the tailshaft. If you buy the standard shifter they supply all the mounts but you need to adapt them to the tailshaft which is pretty simple. The tailshaft mounted shifter they sell should work without any mods but I'm not positive. I have an engine and C4 trans I'm putting together right now so I'll let you know how the tailshaft shifter works.
Don
