Thread: Jag Rear
Old 07-26-2002, 03:14 PM
Hi Fordracer All Dana 44 rears are not alike. The ring gear has different bolt pattern. Their are a couple of different carriers for the 44 The axles are 18,28,30 spline. I converted my Jag rear to a 30 spline Locker and the ring gear would not line up the holes. I had to drill out the carrier to make it fit. Make sure the bolt pattern will fit on the carrier and the stub shafts will go into the carrier. If you get a 4-wheel drive mag. they have alot of drivetrain parts for sell. There prices are they good,and a couple have a lifetime warranty of the rear case breaks. No Charge. Check this out before you deceide on what you have to do. Rick Lake
