Old 07-29-2002, 03:18 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Fuel pump?!
EFI fuel pump is in tank and puts out too much pressure for carb. Need to convert to either carb'd in-tank fuel pump, or mechanical fuel pump on timing cover with just a pickup in the tank. If mechancial pump, need to put eccentric on cam to drive it, and an timing cover to mount fuel pump on. Ford did away with fuel pump mount on late EFI timing covers because fuel pump mounts in tank.
