Thread: FE Misfire
Old 07-30-2002, 04:34 AM
Bruce Botti Bruce Botti is offline
Chopper,
Bill sent them because yellow wires were spec'd. They had sat on the shelf for years.....and like you said, these things happen. Bill always works to keep his customers happy.
After making the above changes and still having the misfire, I got a set of wires that I know are good, and I changed the power valve and set the accelerator pump and floats to Holley's specs. It still misfires. Today I will change the cap and rotor. I'm also curious about the Crane ignition unit. They mentioned connecting a capacitor from the main 12 volt line to ground if the battery is mounted in the trunk. I'll give that a try.
Thanks for your help!
Bruce
Bruce Botti
Botti Enterprises
www.cobra427.iwarp.com
