Old 07-31-2002, 10:22 AM
cobrashoch cobrashoch is offline
Cobra Make, Engine: Home built, supercharged 544cu/in automatic
I would check with Milodon to see what block casting that those caps fit. If it is a DOVE 2 bolt block that is required you may have a tough time finding one and they can be a bit dicey on costs to. There is other caps out there that fit the garden varity DIVE, etc. blocks to. I think the Milodon caps are the cheapest ones out there though. BTW- That angled bolt cap is called a spayed cap. There is some out there that are conventional strait up and down. If you use conventional bolts on the mains a spayed cap is better. If you use studs there isn't any difference between the two.
cobrashock
Ron Shockley
