Old 08-01-2002, 03:57 AM
boxhead's Avatar
boxhead boxhead is offline
Default low wattage bulb
In Australia the small bulb is used for the parking lamps. The headlamp switch has off position, park lights position ie number plate lights and tail lights and the front parklights, and main beam lights ie low beam rear lights as above and low beam driveing lights. The hi beam is switched on generally with a seperate switch on the steering colomn.
Cruising in 5th
