Old 08-01-2002, 07:07 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
When you say you are using the factory module do you mean the dist module or the duraspark box with the dist. If you are using the Holley system is it a standalone system or a "kicker" box to be used with the duraspark box. There should only be 3 wires from the dist. You only need to use 2 of them, the black wire isn't used. Let me know what you have and how you want to wire it.
Don
