DScott
Hey Don! I'll try to explain better. My distributor is electronic...with the module that is glued to the side of the distributor. My ingnition system (Holley 800-100) is a box that sites on the firewall. I have a laser shot coil...that is mounted to the firewall and grounded to the engine block. Form the Holley system there are 2 wires I have to conect to the distributor...the white wire....and a red wire. The problem is the wires that come off the module ...which ones do I use? Or....am I doing something wrong...in the intructions from holley they don't show the distributor in the picture...so I have no idea where and which collor wires, I'm to use from the distributor. Also in the info from Holleys drawing all start. From the HP Annihilator#800-100 there are wires Black and Orange...Black to Neg side Laser shot coil....Orange to Pos side Laser coil. Next...Brown to Tach....Purple...and Green ..NOT USED! Next...2 wire separate from other wire bundle BLACK and RED....Red (12 gauge) to Battery Pos......Black wirer...to Battery Neg..then to engine ground. This is were I get mixed up....single wire from Holley system....White wire to......it seems to go up to where wires are comming from a Coil Neg....what Coil....I thought I only had the Laser Shot Coil..to work with? The other RED wire from the Holley system goes to the other side of that Coil Pos? Are thay refering to this Coil as The distributor module.
I'm confused......?
Snake.
P.S. If this doesn't make any sence...I can understand.
