Old 08-04-2002, 10:46 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
Jack, It took me about 10 fuses before I figured that one out. The manual is actually correct if you read between the lines. They tell you to ground the terminal but they don't say remove the wire form the back of the park switch. That's what is grounded. So for everyone else, remove the blue wire from the back of the park switch on the motor and ground it. Don't run a ground to the switch or it will pop the fuse everytime.
Don
