Old 08-06-2002, 09:27 AM
Dan Stryffeler Dan Stryffeler is offline
Cobra Make, Engine: Everett-Morrison, 347 Tri-power Stroker
Mike, the 25th still looks good.
Interesting weekend... fuel pump jammed Friday night, took it apart and cleaned it Saturday am - so far so good. Back left rotor covered with grease on the inside, found it when I removed the tire to service the fuel pump - yikes! Positive connection on the coil down to 1 strand of wire at the crimp-on connector, crimped on a new one. Noticed oil pressure bouncing between 50 and 60 lbs on my trip to Perrysville on Sunday, usually the oil is pegged at 60lbs on the highway, the car was 3qts low on oil???? Never have figured out total capacity what with Caton pan, remote filter, oil cooler and related oil lines - maybe 8-10 qts?
Enough gremlins for a while!
Dan
