Old 08-08-2002, 04:53 AM
427 S/O's Avatar
427 S/O 427 S/O is offline
I drilled and welded a threaded boss in the bottom of the oil cooler to accept an allen plug, also drilled a 3/4 inch hole in the body directly under the cooler, this drains most all the oil. a little extra effort but, I wanted it.
A hydraulic guru told me, for every 90 degree fitting you install, it's like adding 3 feet of hose. Not sure if this applies to automobile oil lines?.
Perry
