Old 08-15-2002, 08:11 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
It depends on your deck height, which is determined by what year the block was cast, how much it has been decked, and how much needs to be machined off this time to clean it up. Get the wrist in as close to but not yet into the oil control ring. Get the longest con rod you can fit into your combo. Getting a generic kit you may end up with the pistons coming out of the bores a little bit.
