Old 08-16-2002, 10:30 PM
Turk's Avatar
Turk Turk is offline
Cobra Make, Engine: What Cobra?
Send a message via Yahoo to Turk
I can and HAVE proved Water Wetter works. Controlled conditions. On a test stand.!
Same outside temperatures, same air flow same garage same engine, same fuel same oil.
1-Ran the engine with 50% water 50% antifreeze
2-Ran the engine with 75% water 25% antifreeze
3-Ran the engine with above combinations with 2 bottles of Water Wetter.
4-Ran it with water and Water Wetter only.
Exactly as spelled out in the back of the bottle. 20 plus degree temperature variation.
I was then told my engine was breaking in, of course it would create less friction and thus run cooler. Drained the coolant again and added water and antifreeze. 50-50-. Watched the temperature climb back 20 degrees and drained it again.
Filled it with distilled water and 2 bottles of Water Wetter ,,,,down 20 degrees.
How much more of a testimonial do we need. I am not a retailer or a distributor for the stuff, just passing on all the experimentation I did to satisfy my own scepticsm.
Mojave-Death Valley-Hot August Night (100 temperatures outside, 2-3 miles an hourr crawling in traffic for 30 minutes at a time), 6 Dyno pulls. Either the temperature gauge is broken or the stuff works.
Hardly "junk".!
TURK
OBAMA IN in 2012
