Thread: Pedal assembly
Old 08-17-2002, 08:57 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
The same pedal assembly is still used. It sounds like the rod from the master to the pedal is either to long or to short depending on which side of the pivot the rod is mounted. Normally the clutch sits a little higher than the brake and the brake is higher than the gas pedal. I would look and see if the rod is adjustable. If not it would be easy to modify the mounting point to raise the pedal.
Don
