Old 08-19-2002, 08:30 AM
Flyin_Freddie's Avatar
Flyin_Freddie Flyin_Freddie is offline
Cobra Make, Engine: Superformance #770, Stroked 351W (393 cubes) w/ Tremec TKO-600, 3.27 Torsen locker, 'Hi-Tech' Blue w/ White Stripes, Wilwoods, Bilstein coil overs...and a big ear-to-ear grin!
Post Alternator/Voltage Rgulator Problem....
The red light indicates the alternator or voltage regulator is not putting out enough power. When you first turn the switch to the 'ON' position, the light glows because the alternator isn't turning and producing power. It should go out once the car is started and running. If not, suspect a bad alternator, or voltage regulator.
Since I don't know if you're running an alternator with an internal voltage regulator, or not, I can't be sure if your voltage regulator could be the problem. Normally, for internal voltage regulators the red light will glow if a diode goes bad in the regulator. This causes a back circuit that will run down your battery while the car is off. It normally causes the red light to glow a little - sometimes very faintly - when the car isn't running.
I'd remove the alternator and take it to a shop that can test it. I suspect a bad alternator. It won't show up immediately, but this will run your battery down PDQ.
If the alternator tests good, then I'd suspect a bad regulator. They're inexpensive, and if it's in question - replace it. If that still doesn't solve the problem, then I'd suspect a faulty, or intermittent ground somewhere.
Finally, it may even be a faulty igniton switch...pretty remote, but it could happen.
Hope this helps...
Flyin_Freddie
"An opinion on everything...an expert at nothin'!"
WARNING: The opinions expressed herein do not necessarily represent those of the management, editors, or owners. We welcome differing opinions, and recognize our responsibility to offer differing views. May cause drowsiness, restlessness, or irritability. Do not operate heavy machinery while using this product. Void in Alaska, Hawaii, and Puerto Rico, or where prohibited, licensed, or regulated by law. We reserve the right to limit quantities. Offer good while supplies last. No substitutions allowed. Please observe posted speed limits. Professional driver on closed course. Do not try this at home. Please wear your seatbelt at all times. Close cover before striking. Use at own risk. Please dispose of properly. Drink responsibly. Prolonged exposure to vapors has been shown to cause cancer in laboratory animals. Do not use this product of you are pregnant, or plan on becoming pregnant. Intentional misuse by deliberately concentrating and inhaling fumes can be dangerous. Always wear safety glasses. In case of eye contact, flush with water and seek immediate medical attention. For occasional use only as directed. Avoid prolonged skin contact. Discontinue use if rash develops. If symptoms persist for more than three days, seek professional medical attention. Hearing protection required beyond this point. Danger: Hot surfaces. Use as directed. Proceed at own risk. Caution: Filling may be hot. Please don't litter. Actual results may vary. It is a violation of Federal Law to use this product in a manner other than as intended. Do not use this product if you have an enlarged prostate, or have difficulty urinating.
