Old 08-19-2002, 12:45 PM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
I had the same problem in the beginning. Check your ground strap (sh/be .00 size battery cable) that you should have between your starter and your frame. Mine was bolted to the frame tight but I hadn't cleaned the grounding surface very well.
I hope this helps.
Clois Harlan
"Let's roll"
"Be part of Something Good
