Thread: Rear Main Leak
Old 08-20-2002, 06:24 AM
brandonF brandonF is offline
An 86 or 87 ford 302 will have a one piece rear main seal. You don't need to remove the oil pan to replace it. you have to remove the trans and flywheel. Then you can a small sheet metal screw, screw it into the seal half way. Then use a pair of pliers to pull it out.
