Old 08-20-2002, 01:52 PM
Flyin_Freddie's Avatar
Flyin_Freddie Flyin_Freddie is offline
Cobra Make, Engine: Superformance #770, Stroked 351W (393 cubes) w/ Tremec TKO-600, 3.27 Torsen locker, 'Hi-Tech' Blue w/ White Stripes, Wilwoods, Bilstein coil overs...and a big ear-to-ear grin!
Did you have the alternator checked...? If not, how do you know the "alternator seems fine"? Not trying to get on your case, but faulty alternators look just like good ones....they just don't charge....and what were your symtoms again?
Seriously, check out that alternator. Sounds like you may have had a flakey voltage regulator because your red light went out when it was replaced. Now, we need to be sure your alternator doesn't have a broken field coil, or something else that's causing it not to produce a charge. A shop specializing in starters/alternators should be able to check it for you for little or nothing. But, you'll have to take it off and take it to them first.
If your alternator checks okay, and you know you've already replaced the voltage regulator, hell, the only thing left is wiring....maybe a bad ground wire, loose or intermittent contact, bad battery - maybe, but probably not. Faulty or intermittent ground wires would probably be in your ammeter circuit. I'd be willing to bet everything's okay with your alternator, voltage regulator, and battery, but your ammeter has fried it's guts....just a guess here.
Check out that alternator and let us know what turns up.
Anyone else got any more ideas....?
Flyin_Freddie
"An opinion on everything...an expert at nothin'!"
WARNING: The opinions expressed herein do not necessarily represent those of the management, editors, or owners. We welcome differing opinions, and recognize our responsibility to offer differing views. May cause drowsiness, restlessness, or irritability. Do not operate heavy machinery while using this product. Void in Alaska, Hawaii, and Puerto Rico, or where prohibited, licensed, or regulated by law. We reserve the right to limit quantities. Offer good while supplies last. No substitutions allowed. Please observe posted speed limits. Professional driver on closed course. Do not try this at home. Please wear your seatbelt at all times. Close cover before striking. Use at own risk. Please dispose of properly. Drink responsibly. Prolonged exposure to vapors has been shown to cause cancer in laboratory animals. Do not use this product of you are pregnant, or plan on becoming pregnant. Intentional misuse by deliberately concentrating and inhaling fumes can be dangerous. Always wear safety glasses. In case of eye contact, flush with water and seek immediate medical attention. For occasional use only as directed. Avoid prolonged skin contact. Discontinue use if rash develops. If symptoms persist for more than three days, seek professional medical attention. Hearing protection required beyond this point. Danger: Hot surfaces. Use as directed. Proceed at own risk. Caution: Filling may be hot. Please don't litter. Actual results may vary. It is a violation of Federal Law to use this product in a manner other than as intended. Do not use this product if you have an enlarged prostate, or have difficulty urinating.
