Old 08-20-2002, 03:23 PM
GreyWolf GreyWolf is offline
Thumbs up 351 Cleveland long block plus
'72 351C. BLOCK - bored =.020", Fel-Pro gaskets, Moroso oil restrictor kit, alum "COBRA" "T" oil pan (7 1/2 qts).
ROTATING ASSEM. - KB piston, Sealed Power rings, Clevite 77 bearings, Edelbrock timing chain w/CompCams thrust bearing, Melling HV oil pump w/ARP driveshaft, Rhoads lifters, crank micropolished/oil holes chamfered, ARP con rod bolts, alum Milodon HV water pump, StreetDamper vib damper w/ARP bolt, Crane RV type cam w/ARP bolt.
HEADS - 2V ported/polished, Crane rocker studs/guideplates, Crane valve springs/retainers/locks, CompCams alum 1.73:1 roller rockers, alum "351 CLEVELAND" tall valve covers, alum PCV.
ACCESSORIES - Edelbrock Performer int. man., Accel dist., ARP s.s. bolts throughout, MSD Heli-Core plug wires.
EXTRAS INC. - ARP head stud kit, chrome bellhousing bolts, CompCams retro-fit hydraulic roller cam (284HR)/valve springs/seat cups/locators/shims/retrainers.
PERFORMANCE - with the cam that's in it, it does 404HP@6000rpm and 416ftlbs@4000rpm with a 600 cfm carb installed.
With the CompCams cam and a 750 cfm carb installed it does 482HP@6500rpm and 454ftlbs@4500 rpm. This is all w/stock 76cc comb chambers which make 9.5 comp and using small tube headers w/mufflers. All these numbers go up a lot if heads milled and large tube headers w/no mufflers used. 10:1 comp = 547HP@6500rpm. $5,000.00 / make offer
