Old 08-23-2002, 05:32 AM
Double Venom's Avatar
Double Venom Double Venom is offline
Curt,
On the GM master the front bowl is for the front brakes, (Ford is just the opposite).
I eliminate the boot that you are referring to, and as the "differential valve or porportioning vlave, we simply use an adjustable valve, (Wildwood available from Jegs for $49.00)
We normally come out of the rear bowl, to the fire wall, up high, to the valve, then to the rear brakes. Simple clean and easily accessible.
See if Don concurs.
DV
