Old 08-24-2002, 11:57 AM
Jahred Jahred is offline
Registered User
Cobra Make, Engine: 67 Shell Valley - Kevlar; 514:TKO
Send a message via AIM to Jahred
Default Hydraulic Throw Out bearing fits
Ok, this may be redundant. My 514/TKO/McLeod set up is equipped with a hydraulic throw out bearing.
Something is leaking. External fluid evident. I assume its just a loose connection into or out of the Throwout bearing.
My immpression is I need to pull the tranny. That sucks hard.
Pending dissassembly, I am considering switching to different set up. Any recommendations on BB applications?
Also, even filling the clutch fluid reservoir is a HUGE pain in the ars. It is buried so deep in the fender it is almost immpossible to pop the springs on it.
Any thoughts on a lower maintenance approach or solution to my leak????
These cars should be so simple!
