Old 08-27-2002, 10:49 AM
ronzara's Avatar
ronzara ronzara is offline
Cobra Make, Engine: Everett-Morrison 351w assembly STILL in progress
Send a message via AIM to ronzara Send a message via Yahoo to ronzara
Don and Snake,
You're right (as usual) my gauge and sender ARE mismatched. I am trying to swap gauges. I found the same gauge with 90 Ohm guts. Available through XKS.com ($32) >>> Cheaper than a new sending unit and should take care of my problem. thanks.
OK, on the AMP gauge...... If I run #130 to one side of the Amp Gauge and then come OUT of the gauge with a Hot wire to ..... say,.... the Fuel gauge, then this would make the Amp Gauge work????
HeadLights.... The switch I am using on the head lights is a standard Plastic toggle I got in my set of dash parts. It has 3 prongs on the back with tapped holes and screws to hold the wires on it. I am guessing this is about a 20 Amp switch. Is there one you recommend that is better suited for the Head Lights??
Do you think this is why the lights are not working?
RZ
Ron Zara
ronzara@hotmail.com
1. "Putting a Chevy Motor in a Shelby Cobra is like CUSSING IN CHURCH!"...... ME
2. "Friends Don't Let Friends Drive Junk"....
