Old 09-04-2002, 06:28 PM
kountzecobra's Avatar
kountzecobra kountzecobra is offline
Default Fan Wiring Question
I purchased a temp switch for my electric fan. It screws into the block and goes to ground at 185 degrees. I have no wiring info on it. Should I wire it into the ground on my Fan motor or should I wire it into the ground on the Fan Relay? Relay kit was from Painless Wiring. Also, how can I wire an override switch into the circuit? Thanks, David.
