Old 09-04-2002, 07:10 PM
ron427 ron427 is offline
I would have the temp switch ground the relay. Tie into this same circuit, run to a switch and ground the other side of the switch. This will give you the an on-off that will bypass the temp control switch. When the switch is off, the fan will still work by temp control.
