Old 09-06-2002, 08:51 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
I have gone to the NAPA store several times to look at all the hoses on hooks to find one that has the bend I need in the diameter I need. Often use just half the hose. Connect them together with stainless hardpipe. Have your welder run a bead around the outside at the ends so you will have a rim to prevent blowoffs.
