Old 09-06-2002, 09:48 PM
Art Art is offline
Send a message via AIM to Art Send a message via Yahoo to Art
Default Rear main leak
My first post, be gentle....
My experience from re-occuring rear main seal leaks are caused by the following; (1). Not enough crankcase venting. Guys buzz motors up to 7K with a PCV valve and a vented oil cap.... Popped out intake gaskets and leaky rear mains! Crankcase pressure has to go somewhere....Doooh! (2). Not enough lube on the seal at start-up... Dry start-ups will pour oil instantly, but slow enough to leave a 6" diameter of 20W50 on the floor after a romp! Use plenty of Moly assembly lube on the rear seal. (3). Not the seal at all, but a leaky intake gasket, block plug or rear camshaft plug, Flywheel bolts should be sealed, on factory SB motors, the holes for the flywheel bolts go all the way through into the crankcase.
Respectfully disagree with the previous poster concerning a 2 piece seal "as good as" a one piece... No way, Jose'! IMO, one piece seal is far superior than a two piece split seal. I believe 1980 and newer Windsor and 5 Liter engines carried the better one piece rear main seal.
It is better to go into a curve slow and come out fast than go into a curve fast and come out dead.
Sir Sterling Moss
