Old 09-08-2002, 06:49 AM
OhBuoy OhBuoy is offline
Cobra Make, Engine: B&B w/FRPP 347ci 450HP Crate
Send a message via AIM to OhBuoy
Okay, I am not the only odd ball out there because B&B's demo has the alternator in the same spot, and a couple pics in their build CD show the same bracket. My builder used a Lincoln accessory bracket, which I needed to cut the Power Steering portion off of. This thing has to be a 20-30 lb hunk of ugly aluminum. I am thinking of moving the alternator to the passenger side. I bought the March Bracket set, and it puts the tensioner in line with the upper radiator hose. What brackets are you guys using? Where did you put your coil (mine will interfere with the alternator where it is mounted on the heads now).
Looking for input.
Tom
