Old 09-08-2002, 10:35 PM
A Snake A Snake is offline
Cobra Make, Engine: Contemporary CCX33868 Sold. Just "playin' the boards now."
Maybe a silly question, but when you jacked it up, did you do it under the spindles or under the center of the frame? Unless you already have, try jacking up BOTH sides equally from points under the spindles and try again. I'm sure you did, but,you might also look at your inner fenders for black marks.
Other than that, I can't think of anything off hand that sounds like a tire rubbing, except a tire rubbing. Bearings growl and rumble, brakes squeek and grind....
"If some is good, more is better.
And too much is just enough."
--Carroll Shelby
