Old 09-10-2002, 03:30 PM
gman gman is offline
Cobra Make, Engine: A&C 460
Roscoe, I consider myself pretty meticulus, I think I have the motor in the chasis as straight as possible, dead center . chassis at 0 degrees level, (with digital level/protractor) motor 3 degrees slope rear. Could not get the motor located with the dimension to the header as per manual, Gave Joe a call and he gave me a number from crossmember to centerline of water pump, thats how I set the elevation. Used a number from another club member for the front to back. also the drivers side header matched the manual number for the pass side. Am Iwrong to think both header should be directly across from each other? They are 1" different.
